Dear Renntech,
I had just parked my 996MY99C2 and upon locking the car with the remote, I got a double horn beep back and checked to see if the doors indeed had locked. The doors were unlocked. I tried again with the same result, and then opted for locking with the key. The driver-side door locks but the passenger side remains unlocked with the double horn beep to follow. However, the trunk, engine compartment, and gas lid are locked (and does not disengage lock with key opening).
Once home I inserted my laptop with Durametric cable and read the alarm fault memory.
Fault codes as follows:
34: interior sensor faulty (status present)
58: tank servo motor not energized (status present)
60: central locking limit position (lock not reached)
33: interior sensor faulty (status not present)
46: control locking synchronization (status present)
61: central locking limit position (status not present)
The lights are all inoperable inside the car. The window motors does not operate with controls, but the windows (both sides) lower and close with the doors closing.
The alarm system fuse B8 (15AMP) seems OK.
Overall it seems that the alarm system is out of sync with the doors OR the passenger side lock mechanism is bust.
Any help is good help!
Sincerely,
Hans
Dear Renntech,
Sincerely,
Hans
Hi , Its faults like this as iMO the alarm system is the achilles heel of our cars.
96-40 Fault code 34
Passenger compartment monitoring sensor, short circuit
to B+ or faulty
Diagnostic conditions
• Alarm system activated
Possible cause of fault
♦ Short circuit to voltage in the wiring between the alarm system
control module and the passenger compartment monitoring sensor
♦ Passenger compartment monitoring sensor faulty
Affected terminals
Plug A, terminals 8 and 24
Diagnosis/troubleshooting
Work instruction Display OK If not OK
1 Check supply voltage of
the sensor
♦ Switch off ignition
♦ Pull off the plug on the passenger
sensor
♦ Measure voltage between the
plug on the passenger compartment
monitoring sensor pin 1
and pin 4
> 11 V
⇒ Step 2
Check or repair wiring
harness
→ End
2 Check the wiring from
monitoring sensor to
alarm system control
module for short circuit to
B+
♦ Pull plug A off the alarm system
control module
♦ Switch on ignition
♦ Measure voltage between plug A
on alarm system pin 24 and
ground
on alarm system pin 8 and
ground
0 V
⇒ Step 3
Repair wiring harness
→ End
3 Check the wiring from
module for open circuit
♦ Measure resistance between
plug A on alarm system pin 24
and plug on passenger compartment
monitoring sensor pin 3
plug A on alarm system pin 8
monitoring sensor pin 2
< 5 Ω
⇒ Step 4
→ End
4 ♦ Replace passenger compartment monitoring sensor → End
96-60 Fault code 58
No current in tank servomotor despite relay actuation
• Central locking system actuation in the direction "safe" or
"locked"
♦ Short circuit to ground/open circuit in the wiring between the
switching element for the filler flap and the alarm system control
module
♦ Open circuit in wire between ground point 7 and alarm system
control module
♦ Switching element for filler flap faulty
♦ Control module faulty
Affected terminals
Plug B, terminals 1, 5 and 10
1 Check wire between
system control module
for open circuit
♦ Pull plug B off the alarm system
control module
♦ Measure the resistance between
plug B pin 1 and ground
< 5 Ω
⇒ Step 2
→ End
2 Check the wiring from the
filler flap to the alarm system
control module for
short circuit to ground
♦ Pull plug off switching element
for filler flap
plug B on alarm system control
module pin 5 and ground
module pin 10 and ground
∞ Ω
⇒ Step 3
→ End
control module for
open circuit
module pin 5 and pin 2 on plug
of switching element for filler
flap
module pin 10 and pin 1 on plug
flap
< 5 Ω
⇒ Step 3
→ End
3 Check output signal of the
module
♦ Select "Filler flap" in menu item
"Drive links"
♦ Perform a drive-link test and
simultaneously measure the voltage
on the plug of the switching
element for filler flap, pins 1 and
2
A short voltage
pulse can be measured
with the digital
multimeter
⇒ Step 4
⇒ Step 5
4 ♦ Replace switching element for filler flap → End
5 ♦ Replace control module → End
96-62 Fault code 60
Central locking limit position - locked not reached
• Control of central locking system in the direction of "locked"
♦ Switch for central locking faulty
alarm system control module, switch for central locking or door
locks
♦ Driver’s/passenger’s door lock faulty
Affected terminals
Plug A, terminals 5, 28, 29, 30, 32
Plug B, terminals 8 and 9
During troubleshooting, the micro switches of the door locks are
tested in Step 4. The test is to be used only for vehicles with "safe
position". USA vehicles do not have a "safe" position; "Driver’s door
secured" and "Passenger’s door secured" are therefore displayed
during the "Input signals" test.
1 Check switch for central
locking
♦ In the menu item "Input signals",
select "Central locking
system button"
♦ Actuate central locking system
switch and check the statuses
on the screen
⇒ Step 2 ⇒ Step 5
2 Check leads between the
module and the door
locks for short circuit to
ground
♦ Pull plugs A and B off the
♦ Pull plug off both door locks
plug A on alarm system control
module pin 28 and ground
module pin 30 and ground
module pin 32 and ground
module pin 8 and ground
module pin 9 and ground
∞ Ω
⇒ Step 3
→ End
3 Check leads between the
module and the door
locks for open circuit
module pin 5 and pin 7 on plug
of door lock on driver’s side
module pin 28 and pin 7 on
plug of door lock on passenger’s
side
module pin 30 and pin 3 on
plug of door lock on driver’s
side
module pin 32 and pin 3 on
side
module pin 9 and pin 2 on
plug of the driver’s side and
passenger’s side door locks
< 5 Ω
⇒ Step 4
→ End
4 Check micro switches of
the two door locks (possible
detection of faulty
driver’s/passenger’s
door lock)
♦ Push plugs A and B back onto
the alarm system control module
♦ Reconnect plugs to both door
locks
♦ Close doors
♦ Vehicle not secured and not
locked
♦ Select "Driver’s side locked",
"Passenger’s side locked"
"Driver’s side secured" and
"Passenger’s side secured" in
menu item "Input signals".
Driver’s side not
locked
Passenger’s side
not locked
Driver’s side not
secured (not applicable
to USA vehicles)
Passenger’s side
not secured (not
applicable to USA
vehicles)
⇒ Step 12
⇒ Step 11
5 Check switch for central
locking
♦ Remove switch for central
locking and pull plug off the
switch
pins 4 and 1 on the central
locking switch
Central locking
switch actuated in
"close" direction
< 5 Ω
Central locking
switch not actuated
in "close" direction
∞ Ω
⇒ Step 6
Replace switch for
central locking
→ End
6 Check switch for central
locking
pins 4 and 2 on the central
locking switch
Central locking
switch actuated in
"open" direction
< 5 Ω
Central locking
switch not actuated
in "open" direction
∞ Ω
⇒ Step 7
Replace switch for
central locking
→ End
7 Check the wire from the
central locking switch to
the control module for
short to ground
♦ Pull plug off switch for central
locking
control module
plug A on control module pin
29 and ground
∞ Ω
⇒ Step 8
→ End
8 Check the wire from the
open circuit
29 and plug on switch for central
locking pin 1
< 5 Ω
⇒ Step 9
→ End
9 Check the wire from the
open circuit
pins 1 and 2 of plug for central
locking switch
approx. 180 Ω at
20 °C
⇒ Step 10
→ End
10 Check wire from fuse C 3
to switch for central locking
on the central locking system
pin 4 and ground
> 11 V
⇒ Step 12
Check fuse C 3 or
repair wiring harness
→ End
11 ♦ Depending on the test result of the input signals test in
step 4, replace the driver's/passenger's door lock
→ End
12 ♦ Replace alarm system control module → End
96-39 Fault code 33
♦ Passenger compartment monitoring faulty
Affected terminals
1 ♦ Replace passenger compartment monitoring sensor → End
96-51 Fault code 46
Central locking synchronisation
• Central locking system controlled in "safe" or "locked" position
♦ Short circuit to ground/open circuit between alarm system control
module and door locks
♦ Door lock faulty
Affected terminals
Plug A, terminals 5, 19, 28, 30, 32
Plug B, terminal 9
tested in Step 1. The test is to be used only for vehicles with "safe
1 Check micro switches of
both door locks
♦ Connect PST 2 and switch on
ignition.
♦ Close doors
♦ Do not lock or secure the vehicle
♦ Select the following switch positions
in the "Input signals" menu
♦ Driver’s side secured
♦ Passenger’s side secured
♦ Driver’s side locked
♦ Passenger’s side locked
Driver’s side not
secured (not USA)
Passenger’s side not
secured (not USA)
Driver’s side not
locked
locked
⇒ Step 4
⇒ Step 2
2 Check wiring from control
module to door lock
for short circuit to ground
♦ Pull plugs A and B off the control
module
♦ Pull plug off the door lock with
the incorrect switch positions
from step 1
plug A on control module pin 5
and ground (if on driver’s side)
or pin 28 on the control module
and ground (if on passenger’s
side)
∞ Ω
⇒ Step 3
→ End
3 Check wiring from control
module to door lock
for open circuit
from step 1
and plug on door lock pin 7 (if
on driver’s side) or pin 28 on the
control module and pin 7 on the
door lock (if on passenger’s
side)
< 5 Ω
⇒ Step 6
→ End
4 Check leads from the
module to the servomotors
ground
♦ Pull plugs off both door locks
♦ Pull plugs A and B off the alarm
plug B on control module pin 9
and ground
plug A on control module pin 19
and ground
∞ Ω
⇒ Step 5
→ End
9601 Fault code 46 96-51 page 3
Alarm system I 48
46xxxi48
96
Printed in Germany – 4, 2001
5 Check leads from the
for open circuit
and pin 2 on plugs of the right
and left door locks
and pin 9 on plugs of the right
and left door locks
< 5 Ω
⇒ Step 7
→ End
6 ♦ Replace right or left door lock → End
7 ♦ Replace control module → End
96-63 Fault code 61
Central locking limit position - unlocked not reached
• Control of central locking system in the direction of "unlocked"
♦ Wrong country coding
alarm system control module, central locking switch or door
locks
♦ Door lock (driver/passenger) faulty
Affected terminals
Plug B, terminal 3
Note!
1 Check coding ♦ In menu item "Country coding",
check whether the alarm system
control module is correctly
coded for the place of
use
⇒ Step 2 Recode the alarm
system control
module (country
coding)
→ Ende
2 Check central locking
switch
system button"
on the screen
⇒ Step 3 ⇒ Step 5
96-63 page 2 9601 Fault code 61
61xxxi48
96
module and the door
ground
module pin 3 and ground
∞ Ω
⇒ Step 4
→ End
4 Check leads between the
module and the door
side
on plug of door lock on passenger’s
side
driver’s side
side
module pin 3 and pin 2 on
< 5 Ω
⇒ Step 5
→ End
5 Check micro switches of
detection of faulty
door lock)
locks
♦ Close doors
locked
Driver’s side not
locked
Passenger’s side
not locked
Driver’s side not
to USA vehicles)
Passenger’s side
not secured (not
applicable to USA
vehicles)
⇒ Step 12
⇒ Step 11
6 Check central locking
switch
♦ Remove central locking switch
and pull plug off the switch
locking switch
Central locking
switch actuated in
"open" direction
< 5 Ω
Central locking
switch not actuated
∞ Ω
⇒ Step 6
7 Check central locking
switch
locking switch
Central locking
switch actuated in
"open" direction
< 5 Ω
Central locking
switch not actuated
in "open" direction
∞ Ω
⇒ Step 7
♦ Pull plug off central locking
switch
control module
29 and ground
∞ Ω
⇒ Step 8
open circuit
locking pin 1
10 Check the wire from the
open circuit
locking switch
approx. 180 Ω at
20 °C
⇒ Step 10
11 Check wire from fuse C
3 to central locking
switch
on the central locking switch
pin 4 and ground
> 11 V
⇒ Step 12
Check fuse C 3 or
→ End
12 ♦ Depending on the test result of the input signals test in
step 4, replace the driver’s/passenger’s door lock
→ End
13 ♦ Replace alarm system control module → End
sorry, theres loads of information there from the workshop manual. Its assumed in the manual that your using PST2 but durametrics will do the same job.
(The information is from my 996tt workshop manual CD and is pasted in order as it was on the page. the information is in table format on the computer but is printed as a list so you have to follow the steps carefully)
Hope this helps and I will be following the outcome so please keep us all updated. As i said earlier the alarm system is so complicated its a bad point with the car IMO.
With that many faults, i would check the Alarm/cl module has not got wet. If the door seals or the seals inside the door cards are poor the water collects in the lowest point in the car, which just happens to be where Porsche fits the Alarm / Cl module. :rolleyes:
Frank :)
Edited by Sunnyside
  • 3 months later...
I've the 96-39 Fault code 33...
Replaced passenger compartment monitoring sensor, but nothing happened..
I'm following the instruction for the fault code 32 (it look to be the same as 34) I have a battery voltage displayed instead of 0, now, how I can check and repair the wiring harness??
which pin are you getting voltage on. It says to check A24 to ground and also A8 to ground. If not 0v then replace sensor.
On the cct diagram when you have disconnected plug A from the alarm /cl module and check A8 to ground the alarm siren would appear to still be connected to A8 as well. In other words A8 is connected to A2 on the interior sensor and also pin A2 of the Siren. The siren might be causing the 12 v on line A24. Pull off the plug to the siren and see if the voltage drops to 0v.
A24 only goes to A3 on the sensor so any voltage on that with the interior sensor plug disconnected A24 to A3 can only come from a short in the wiring/wiring fault.
I'm having voltage ON at pin 24 but I already unplugged the siren and the interior sensor before testing, at this point should I try to connect 24 to 3 with a straight line?
post-36228-0-73230900-1323099608_thumb.j
but.... should I check the pin 24 and 8 on the control unit alarm system or should I check pin 24 and 8 on the plug A by itself?
They way I read it, its asking to check the wiring.
Ok... I checked both, so actually I don't receive signals from the wiring, the wiring harness is ok! is it possible that the new passenger compartment monitoring sensor is broken? will try to get another one tomorrow at the dealer...
Have you checked pin 1 & 4 on the sensor plug. 1 iIRC is the 12v supply and 4 is earth. Perhaps you have lost the earth return?? Or the 12 v supply.
have you any other alarm module fault codes??
Yes, I've checked pin 1 and 4 on the sensor plug, I can read the battery voltage... Anyway I finally had a new sensor (number 2) from the dealer, now I have fault 33 & 34!
Update, I do not have the Alarm Siren and the tilt sensor, I checked the compartment monitoring sensor by closing the car with the remote and keeping the window open, after 30s if I move my hand inside the car the alarm horn goes on! so the sensor is actually working???
