Here's one for ya...
Started the car up to warm it up this morning (been freezing here lately). While it wamed I opened the engine bay and for some reason I took the oil cap off (I was checking for that horrible yellow sludge). As I did this the engine started to cough and splutter I so quickly put the cap back on and everything stabalised. It occured to me that the cap and the oil fill tube must somehow effect compression and that if a tiny bit of air was getting sucked in it could have effect on performance. So just for kicks I put a piece of thick cling film over the oil fill tube and placed the cap back on. Whoa! What an amazing difference. Seems my 996 just found a good few extra pony's. My cap is the new green type. Only got it last year. But me thinks these things still let air in. Any comments?
Berny
By taking the oil filler cap off you will have introduced an air leak and the ECU will richen the mixture accordingly, hence the rough running. Small leaks, like a leaking cap, can cause the idle speed to raise 3-400 rpm, and again it adversly affects the mixture control. If you have a scanner, plug it in and check the idle speed (should be 680 rpm), and also see if you have error codes.
Richard
Taking the cap off will eventually cause a CEL. The crankcase ventilation is part of the emissions control.
Check the inside of the cap for a black o-ring if it's not there that would explain the leak - but also usually causes a CEL. Better make sure it didn't fall out when you took the cap off too.
Checked the cap and the O-ring is there....thank the Lord.
It's weird, the cap seem to fit perfectly and the car drives perfectly normal (especially with the new gearbox ;) ) but it seems to have more punch with the cling film on. Weird!
that is pretty neat. I actually have had that problem causing a CEL. I am going to try that wrap because they said they replaced the oil cap but it looks old to me :)
