Took 2003 Boxster S and had it smogged.
It was put through the California dyno cycle.
After running through the test the car had the ABS fault code on dash.
I assume this is probably due to the speed differential between the
front and back axles.
So is this something that be reset w/o a tester or do I need a tester to reset/test for codes?
Chuck
Same thing happened to me when I put mine on the dyno. It should reset itself after you drive a few miles. I thought I needed to have the dealer reset mine but as I was driving to the dealership it reset on it's own.
Chuck
Normal -- should reset on it's own.
As noted it has reset on it's own
Sort of thought that, but needed to check
Thanks for being a resource guys
Chuck
