I have removed my spare tire and shed a few pounds up front. Now, there is a spear-like bolt on which the tire was mounted remaining and I would like to remove it.
Are there any instructions on accessing the thing before I start pulling back carpet and who knows what to get at the thing? I would like to have some idea of what to expect or look for before diving in.
thanks in advance,
kristap
It slides into a recess in the body so you should be able to lift and wiggle it out.
Isn't the spare tire factored into the crash barrier protection? That's what I've heard and that's why I have left it in my car. :o
You slide it to the passenger side a bit and then it falls out of the holder. If I remember correctly there is a slit in the carpet that permits you to do this so you do not have to remove the carpet.
I've read this in a thread on rennlist sometime back. I am not convinced this is the case. In fact I would think that the tyre and all the jacking equipment would make more of a mess of your legs. In the later models you don;t get a spare.
I have removed mine bacuse I am doing a long trip to Spain in May and need the luggage space. This is the answer: http://www.carnewal-europe.com/cpx_p010.htm
There is an old bulletin for the Boxster that warns against removal because it is part of the crash protection.
Years ago I found the site that did computer generated crash anaylsis for Porsche and they had a neat image of Boxster as if it had been hit in the front.
Some of the AWDs dont have a spare - but they have a front differential.
