A clicking/tapping noise under the dash on the passengers side occurred this morning as I started my 1999 996. At the same time the A/C blew hot air. It sounds like the compressor is kicking in but hot air is all I get with the intermittent under dash noise. As always, you folks thoughts are very much appreciated.
Edited by Doug
It seems that there may be a couple of things going on here. The compressor very possibly gave up the ghost but this under dash sound is perplexing. Hopefully someone here with a shop manual can post here whats down under the airbag that is a switch, a relay, or anything else that could cause a mechanical clicking noise as though something is trying to turn on and off. Thanks for your help.
Is the noise coming from the passenger side dash vent? That's where the interior temperature sensor is located, and there is a small fan which blows air over it.
A diagnostic check should show up any faults in the control system.
Thanks for responding Richard. It is difficult to pinpoint it that precisely but it's definitely a relay or actuator of some type that is located behind or very close to the passenger airbag. It almost sounds like a pump clicking as it pumps a line up to pressure and then stops after 10 or 15 seconds. A diagnostic would be nice but am just trying to figure out what I may have and whether it could be a DIY.
