Had left side seal replaced in front differential. Still leaked. Took it back to the shop and they found that there is play in the axle. They figure that there is a bad bearing inside. Two questions. Will the front axle assembly from a 997 work in a 996 car I have a 2002 c4s there is one from a 2006 c4s on ebay. Or are there instructions for a rebuild available somewhere?
