I have a 1999 C4 Cab with litronic headlights. The intergrated driving lights use to work when I turn and pull the switch all the way to the left but now it's not working. I checked the bulbs are OK so I think it's the relay. I looking into the fuse panel and there are bunch of them. Does anyont know which one is for the driving lights relay? Or this is some other problems. Thanks in advance.
Daytime Running Lights are relays 6 and 7 - but your US car should not have those unless it came from Canada or someone modded it.
Could be you headlight switch is worn out too.
