I have a 2002 Boxster S and the ignition switch works but key will not come out in the far left position. Steering wheel will not lock and now the air and lights will only work if I start the car and move the switch slightly to the left. I'm sure I need a new switch, but is there a trick to getting the switch out. I removed the rubber cover but thought I'd check here before attempting removal. Seems like something that would't be easy or stealing the car would be simple. Any help would be appreciated.
