The TSB is 2/05 9155 and is available in the document repository area of your dealers eDCS
TU for install are 460
Did you order individual parts or the kit?
The kit should contain all necessary parts minus the correct optical waveguide. ie: holder for module, module, microphone, antenna & holder, wire harness (antenna lead & mic lead) and misc asst parts.
I ordered the part #s listed above, but I just emailed Jeff at Sunset Imports & told him that I definitely want to make sure I get all of the associated equipment (wiring harnesses, etc.) . I ordered nav as well, based on the part #s in the TSB for the Nav retrofit, but I didn't order all of the associated little parts & wires.
I have only seen one Navigation module (997.044.900.70) & telephone module (997 044 900 71). How do you know if this is the complete kit or just the individual part?
I have to say, I think these must be "kit" #s, as someone on rennlist just posted the part #s used in his Nav retro fit, and the nav module # is not the same as the above.
If there is a different # for the complete kit, please advise.
Edited by AnthonySp
Is there any new news on this option 666. Does anyone have it? Does it work? Can it be retrofitted by the dealer?
I'd like to try it with a sim card from my Treo 650. Has anyone successfully accomplished this?
