My car has a Manual Dimmable Interrior Mirror and I want to install the Automatic one.
Is this possible if I purchase and Install 955 731 514 01 ?
Also can I have the Rain Sensor functionality if I purchase it together with the mirror ?
I wonder did someone tried this before?
Cayenne - 9PA1 - 2009
Oktay
I'm almost positive this cannot be achieved as this is usually one of those things that is performed when the car is produced. Good analogy would be getting a sex change. Yeah you might have the vag put in, but the plumbing is still not there.
i have done it on my CayenneTurbo 2009. on Turbo it only needed OEM auto dimmable mirror which I got on ebay for like 100usd it then plugs into 12DC and one wire into overhead controller (under the glass holder). On a non turbo you need to install rain and light sensor which will be a pain and waste of time. easier to get aftermarket dimmable mirror.
Edited by SA321
Well, you might be right if it's something related to engine or suspension. But I did this with my previous car (Audi A6) and it worked just fine. Actually it all depends to your doctor. If you have a good one even the plumbimg will be there :) That's why I wont try doing it by myself.
Well I checked to see that I do have the rain and light sensor installed. In this case I only need the dimmable mirror. I'll try to get the original one. Thanks SA321
I have an S with the manual dimmer but with rain sensor, so I would only need the auto mirror?
if you have a light sensor (middle of dashboard under windshield screen) then you dont need anything else
