I have a 1999 996 6 speed manual and continue to get the CEL with code P1124. Anybody have any ideas? Thank you in advance.
My recollection is tha tcode is for lean fuel/air mixture. Therefore, see if you have any obvious air leaks in air intake. Check to see if gas cap sea lis damaged/leaking as well.
Lastly, if you "google" the P1124 code you will probably find some more ideas as well. Good luck with it!! Demosan :cheers:
