The torque multiplier works better, then you are not lugging a 4 foot torque wrench around and you can use an existing 1/2 drive torque wrench.
Stahlwille makes a torque multiplier 1/2" in 3/4 " out . 169 ft lbs in will produce 590 ft lbs out
Sells for $1500.00
CENTER_NUT.pdfFetching info...
Sells for $1500.00
Thanks for the info. Highly appreciated.
Would you happen to know how much the hazet (OEM) one would cost?
Regards
Edited by Porschephile.me
