I have a 2007 Carrera S (one day I will actually figure out how to download pictures to show it off)and my drivers side radiator fan was not coming on. Maybe this simple fix will help someone else before they start all the research I did. I guess we should always look for the simple fix first. I removed the front tire and wheel well cover to get to the fan. It turned out all it was was a small rock lodged in the fan. I tried to spin it by hand and noticed resistence so I moved it until I felt the debris clear. Worked perfect after that. I hope this saves someone else from undue worry and research about resistors etc.
  • 7 years later...
