hi all i need ur kind help with the following
1-
p0197 Oil temperature
i changed the sensor and still its not working i cant know the oil level coz am getting engine is not worm massage , durametric is giving me this code again and again , i understand it could be the harness or the DME(hopefully not) , how can i check the wiring ? i want to check if the wiring is ok (grounding maybe ?)
2-
4460 Pressure sensor
when i reach the speed of 50kilo/m i get PSM/ABS
how can i troubleshoot the system ?below 50km the ABS seems to work fine
thanks in advance
1-
2-
thanks in advance
1. DME 7.8
1709 P0197 0-37 page 1
DME 7.8
p0197
Printed in Germany, 2000
0-37 P0197
125 Oil temperature sensor - below limit
Diagnosis conditions
• Idle speed
• Time elapsed after engine start-up greater than 5 minutes
Possible fault cause
♦ Temperature sensor faulty
♦ Wiring harness
♦ DME control module faulty
Affected terminals
Terminal III/5 and III/17
Resistance values
60 °C 2.8 - 3.5 kΩ
90°C 1.0 - 1.3 kΩ
120°C 0.4 - 0.6 kΩ
Diagnosis/troubleshooting
Work instruction Display OK If not OK
1 Check temperature sensor
♦ Connect special tool 9637 to
wiring harness (DME control
module plug)
♦ Measure resistance between Pin
III/17 and Pin III/5
2.8 - 3.5 kΩ
(at 60 °C)
⇒ Step 2
Replace temperature
sensor
→ End
2 Check wiring from DME
control module to temperature
sensor for continuity
module plug)
♦ Remove plug connection of temperature
sensor
special tool 9637 Pin III/17 and
temperature sensor plug Pin 2
special tool 9637 Pin III/5 and
temperature sensor plug Pin 1
0 - 5 Ω
⇒ Step 3
Repair wiring harness
→ End
3 Check wiring from DME
sensor for short to
ground
module plug)
sensor
III/5 and ground
∞ Ω
⇒ Step 4
→ End
4 Replace DME control module ⇒ Step 5
5 Perform adaptation ♦ Switch on the ignition
♦ Wait one minute
♦ Do not press the accelerator
♦ Switch off the ignition for at
least 10 seconds
♦ Read out the fault memory
→ End
2. 45-30 Fault code 4460
Pressure sensor
Diagnostic conditions
• Pressure sensor actual value is evaluated and displays an
implausible value
Possible cause of fault
♦ Short circuit to ground/voltage or open circuit in circuit to control
module terminals 25, 26 and 42
♦ Plug connection on stop light switch faulty
♦ Adjustment of the stop light switch not OK
♦ Wiring/ plug connection faulty
♦ Pressure sensor faulty (replace hydraulic unit)
Affected terminals
Terminals 25, 26 and 42
1 Visual inspection ♦ Check the pressure sensor plug
for damage and corrosion
⇒ Step 2 Repair pressure sensor
plug
2 Check supply voltage of
the pressure sensor for
short circuit to ground/
open circuit
♦ Switch off ignition
♦ Pull off pressure sensor plug
♦ Switch on ignition
♦ Measure voltage between pin 3
of pressure sensor plug and
ground
approx. 5 V
⇒ Step 3
♦ Display 0 V:
Short circuit to
ground/open circuit
in circuit between
PSM control module
plug pin 42 and
pressure sensor
plug pin 3
♦ Display > 11 V
Short circuit to voltage
between PSM
control module plug
pin 42 and pin 3 of
the booster pump
pressure sensor
plug, or PSM contol
module faulty
→ End
1-
2-
thanks in advance
1. DME 7.8
DME 7.8
p0197
0-37 P0197
• Idle speed
♦ Wiring harness
Affected terminals
Resistance values
60 °C 2.8 - 3.5 kΩ
90°C 1.0 - 1.3 kΩ
120°C 0.4 - 0.6 kΩ
module plug)
2.8 - 3.5 kΩ
(at 60 °C)
⇒ Step 2
Replace temperature
sensor
→ End
module plug)
sensor
0 - 5 Ω
⇒ Step 3
→ End
sensor for short to
ground
module plug)
sensor
III/5 and ground
∞ Ω
⇒ Step 4
→ End
♦ Wait one minute
least 10 seconds
→ End
Pressure sensor
implausible value
Affected terminals
plug
open circuit
ground
approx. 5 V
⇒ Step 3
♦ Display 0 V:
Short circuit to
ground/open circuit
in circuit between
PSM control module
plug pin 42 and
pressure sensor
plug pin 3
♦ Display > 11 V
between PSM
control module plug
pin 42 and pin 3 of
the booster pump
pressure sensor
plug, or PSM contol
module faulty
→ End
thanks sir for the replay ,,,
but ,i dont have the special tool nor the knowledge to follow these instructions ,,, for now i am really worried about knowing my oil level , so i need to fix the oil temp sensor ,,,
i took alook and the switch it seems fine to me ,,, is there any easy way to solve this problem ?
regards
Be very very carefully testing pins on the DME - Porsche has a special inline tool for doing that safely. I would hate to see you smoke your DME.
Better yet find someone with Durametric, a PST2 or PIWIS tester to monitor the settings safely.
maybe there is way to know which pin refers to oil temp sensor from the DME side so i can check for continuity ?
Been out all day, but had a look at the wiring diagram. Nearly all the signals go to the instrument cluster first not the DME.
Here are the pin numbers required at the instrument cluster:
B18 ground oil level colour Br/Or
B2 Oil level Colour Gn/Bu
B5 Oil Pressure Colour Gn/Rd
A13 Oil pressure switch Colour Gn/Wh
I will look to see if I can find some more .
Frank
Right also found the Motor Oil Temperature goes to the DME pin C5 Colour Gn/Rd.
Apart form oil temp it would appear the DME doe not have anything else to do with the oil pressure or level
Edited by Sunnyside
My problem is with the oil temp ,,, i am getting the code and also i cant read my oil level because the cluster is giving me a msg that the engine is not wormed up ,,,
i changed the oil sensor and still the same problem ,i am thinking of removing the sensor switch to see if i get a different code other than p0197(LOW Voltg) and that will indicate that the harness is fine ??? what do u think ???
Frank
Frank
Why don't you try doing a continuity test from the oil temp sensor to pin C5 on the DME. Remove the plug so its not connected to the dme, then you cant do any harm. See if there is a break in between C5 and the temp sensor plug.
Or run the engine to normal temp, then measure the resistance of the temp sensor.
60 °C 2.8 - 3.5 kΩ
90°C 1.0 - 1.3 kΩ
120°C 0.4 - 0.6 kΩ
I would think you should be in the range of 90°C 1.0 - 1.3 kΩ.
