My 2003 996C2 convertible is in need of new brakes. I was thinking it would be cheaper to buy OEM rather than Porsche original parts, but I cannot find who manufactures the Porsche brakes for my car. Any ideas/part #?
Michael
There should be many aftermarket alternatives at your local reputable parts source.
Aftermarket rotor examples (might have different brand name in Europe). Zimmermann Coat Z, Balo, Sebro, Centric, DBA, Brembo
Aftermarket pad examples (might have different brand name in Europe). ATE, Textar, Mintex
In the USA for alternatives we would go to pelicanparts.com or tirerack.com for example. Not sure about Greece.
If the rotors are not too far out of spec, they can be resurfaced and then you only need to replace the pads and springs.
Brake grease and cleaner are also recommended but do not have to be Porsche brand.
Front
99635140501 Left Rotor
99635140601 Right Rotor
99635294903 Pads (contains 4 pads)
99635195901 Spring/Clips 1 required
99661236500 Wear Indicator Per Pad Set (if the warning indication is on your dash)
Rear
99635240104 Rotor (left or right)
99635293903 Pads (contains 4 pads)
99635295901 Spring/Clips 1 required per axle set
Edited by logray
Thank you logray for the detailed reply.
I was wondering if we know who is manufacturing the actual Porsche part (Porsche does not make rotors or pads). I don't want to go for an alternative, I want the exact same part - I just don't care to pay extra for the "Porsche" logo on the cardboard box it comes in.
I am not 100% positive, but from what I can tell at least according to Pelican Parts who lists these companies as OEM suppliers to Porsche (there could be others as well).
"Textar" supplies pads to Porsche.
"Zimmermann Coat Z" and "Sebro" supply rotors to Porsche.
