I need to know how to take the following out:
Clip part of the seat belt
The actual rear seat belt (how do i get at the inertia reel?, yank out the trim piece or take out the whole C pillar?)
please let me know, i KNOW someone out there has done this b4.
Edited by DeAd-EyE
1. Remove side-panel lining
2. Remove C-pillar
3. Remove automatic belt device (image 1)
Unscrew fastening screw 1 from the deflector 2. Unscrew fastening screw 3 from the automatic belt device 4.
4. Remove seat belt and fitting (image 2)
Press out the covering cap 5 with a screwdriver. Unscrew fastening screw 6. Remove the seat belt with fitting 7 and spacer sleeve 8.
5. Remove seat cushion (image 3)
Pull the seat cushion 9 upwards and out.
7. Remove belt buckle
Press out the cover 10 with a plastic spatula. Unscrew the fastening screw 11 from the metal clip 12 and the belt buckle 13.
thanks a lot loren.
i gotta update my manual set.
in order to properly remove the C pillar you have to take out the a and b right?
Edited by DeAd-EyE
