Can anyone confirm that the 02-05 PSE mufflers will fit a 99 996 C2? They would be coming from an 03 996 C2.
Part Number
PSE (Porsche Sport Exhaust) mufflers
#996-111-131-71 and #996-111-132-71
Edited by cab713
Yes they will fit, I have a set that came off a later car that I installed on my 2000. If the mufflers come with the brackets on them you will need the brackets off the old mufflers. In 2002 Porsche changed the bolt pattern on the muffler brackets and on the mounts/frames on each side of the engine. It is much simpler to change the brackets on the mufflers than the ones on the engine.
