:welcome:
If you want the whole key then you will need to take the old key (and any other keys for the car) or VIN to a dealer to cut the metal portion of the key and re-program the immobilizer.
The electronic portion of the key can be purchased separately but would require programming with the car for the immobilizer.
If you have the old key you can many times transfer the immobilizer "pill" from the old key to the new key and skip programming.
So, which portion do you need or the whole key?
