Related, but this concernes the inner door handle micro switch.
The window will nort lower when the inner handle is pulled, the outer door handle switch works as it should.
According to my opc, the sworn needs adjustment as it seems to be a common fault.
I'd appreciate knowing what to do when the door card is off, following the latest Paulspeeds DIY tutorial...
Thanks !
This is the same problem I had. I replaced the micro switch
but it did not fix the window problem.
It is a little more work but I would replace the door handle
part. I have a DIY on this part. It is a part that does
wear out with use.
Paul
  • 9 months later...
