Good Afternoon,
Am currently cleaning up the dashboard area and noticed that the vinyl pad covering the glove compartment as well as the small edge around the radio are not adhering as they should. Am just wondering if this is glued normally and double-sided tape, so I can properly repair it.
Thanks.
Skip
Good Afternoon,
Thanks.
Skip
Skip,
Those items are glued.
For the glove box cover, any adhesive such as Gorilla Glue will work,
but you must somehow clamp the cover to the door while the glue is drying.
Try posting on Pelican for additional comments.
Good luck,
Gerry
