hi guys
i just got the durametric and it pull a code like 1330 rear convenience system module , anyone experience that problem ,if yes how can i change that module is, where is it located, my back up light not work alarm stop to work , wiper on back too, the trunk wont open and the fuel lid all together
thanks
Reseat/Check left dash fuse 53 (5 amp)
Reseat/Check right dash fuse 31 (15 amp)
These supply power to the rear convenience module.
Module is located in right rear cargo area.
Edited by bigbuzuki
thanks , will check it and let you know, IS that module located to the same compartment as the cd charger
CAYENNE S 2004
CAYENNE S 2004
See the PM I just sent you.
