I have not played with the brakes for 2 years and for some reason the fluid level has increased.
The temp. here is lower than it has been in a while sub 100 degrees, it's about 80 right now is it possible that the fluid is retaining heat and thus expanded? Planning on a flush after replacing the booster just noticedthe level was high, while prepping to replace thebooster as thepedal has been hanging and running away from my foot, causing jerky braking and failure to release without pulling the pedal back with my foot. TIA
