For those of us with half shafts up front, any thoughts on what the engagement depth looks like and how much one can safely shim out the LCAs? Figure that 8-9mm shim stack would net about -2.4 +/- which would also pull the shafts out 1/3". Depending on depth of engagement it's either a nit or an "oh sh*t" and I haven't found specs to determine which.
Interesting question.
Can you balance sliding in the upper strut bearing and shimming out the arms?
Once you choose your shims you slide the shaft back and forth to make sure you have freeplay?
Curious to hear about your findings
