My name is Jacob P. and I have a 1998 boxter S with manual transmission. I recently purchased the car and it ran fine until one day I went to the store and it wouldn't turn over, so I kept trying and I must have started (or attempted to) 15-20 times. I pushed the clutch in extremely hard and it started, everything was fine until later the day I was getting ready to go and it did it again but this time it wouldn't start. So I pushed the clutch in and released the brake and began to roll turned the key as I was rolling and it started right up. Now its been in my drive way for 2 days and I have not been able to get it to start no matter what. The car won't turn over I called autozone and they said it was the starter but I figure I'd get a 2nd opinion here to either confirm or deny this.
So anyone have any diagrams for the solenoid and starter?
I've seen a similar post about this and the switch being bad that the clutch engages allowing the car to start. Someone probably has more specifics or you can try a search to locate the previous thread. Definitely wasn't the starter in that case and circumstances were similar to what you described.
Be wary of Autozone - they mean well but all my past advice from them has equated to purchases for parts that don't fix the problem. There's a lot of knowledge purple on this board and they'll get you on the right track.
Welcome Jacob!
Run a search on the clutch startup switch. You can jumper the switch so that the clutch does not have to be depressed during start-up. (not adviseable for safety reasons) It is a fairly inexpensive part from Sunset.
Here is a link to another thread on the issue. PRESS HERE
Edited by kbrandsma
Jacob,
While you are wiring around the clutch switch in your troubleshooting efforts, make sure the floor mat isn't bunched up behind the clutch pedal preventing full pedal travel.
Bill
+1 on the clutch interlock switch as the issue. And just as a by-the-way, Porsche did not make an S Boxster until 2000..................
