That part was never used on 987-1 series cars only 986 series. The 987-1 series used 997 series part numbers - and there were at least 3 different ones used.
Will it work? I doubt it - but you are welcome to give it a try.
It was Removed from 2004 Porsche Cayenne 3.2 V6 and i found it on ebay uk. Probably, as you suspect, it will not work.....
Thanks anyway, quick as usual
Can you tell me what is the nr. code for my model?
thanks
It will be part number specific to your VIN. I suggest you verify with your OPC/Dealer.
thanks
