I'm doing my research to pick up a 996 cab C2 or C4 [s?] sometime later this summer. To all you cab owners with the plastic rear window - how much do you notice it? My current convertible has a glass rear window and I'm debating how much I'd miss it.
I have the plastic window and find it to be pretty much useless. I've read that the glass window is a bit better but is actually smaller. Most of the time, I have the top down so it's not much of an issue. I use the hardtop from October to May. I guess you may have more issues with a plastic window in Seattle.
Edited by wyovino
No question about it, whenever possible go with the glass. First, with the glass you can use the rear defroster. If you live in a humid climate (I live in Florida), you will use the defroster often in the morning. Also, the plastic windows eventually yellow and crack. I owned a boxster in the past and had water leakage via a small crack in the plastic window. If you have (or are going to purchase) plastic, take a look at GAHH convertible top replacements. The quality is excellent. The fit and finish is close to original, except the rear window is a little smaller. I currently have a used 996 1999 with a replacement GAHH top and am very pleased.
