Want to replce the throttle valve on 03' 996. Do I need to disconnect the battery? And anything special need to do when putting on the new one. I see 5 torx bolts and electric plug for removal. Input would be great. Thanks
As long as the ignition is off you are fine. I would clean the plenum good with throttle body cleaner while you have the old one off. Do not use other cleaners as they are too harsh. The job is pretty straight forward.
Good luck, Tom
