HI
I have a 98 Boxster running a 2004 Boxster S engine and 2002 electrics with DME 7.8. I have only just got everything connected up and test drove it yesterday. I have a few issues which i believe stem from one thing.
ABS light on
Brake warning Light on
No speedo (not working)
Does the Boxster get its speed from the abs pump?
My Wiring loom is from a Boxster without PSM or TC (2002) the ABS pump that a breakers supplied for me is from a PSM car maybe later aswell but told me that it is compatible is this the issue. if so do you know the part number of the abs pump I need so I can get the correct one. Or could it be the cluster does DME 7.8 require a different instrument cluster
Thanks for all the help this forum has given me in this project
Regards
Ross
