My 04 Cayenne Turbo is missing/ rough when cold and threw a code of cylinder #2 lean and misfire. Anyone experienced similar? Had all coil and plugs replaced about 7K miles ago.I'm guessing injector. But I don't know the cylinder number configuration. Thanks in advance.
Swap the coil first to another cylinder and see if the problem follows. If not then do the same with the spark plug - again see if it follows.
Could be as simple as a loose connection or a spark plug they forgot to torque properly.
