My check engine light continues to come on after about 100+ miles of driving after reset. I am continuing to get codes P1411 and P0410. A couple months ago I had 2 other codes P1124 and P0102 but have not seen these codes in a few weeks or so. Does anybody have any suggestions for me? I checked my secondary air injection pump at cold start up and I can feel it vibrating. Thank you in advance for your input.
:welcome:
P0410 Secondary Air Injection System - Signal Implausible (Cylinders 1 - 3)
P1411 Secondary Air Injection Sy.stem - Signal Implausible (Cylinders 4 - 6)
Possible causes of fault:
- Secondary air injection pump is not triggered. - Wiring harness or fuse
- P1411 Secondary air injection pump does not work. - Relay
- Air supply lines restricted. - DME control module
- Electric change-over valve does not work. - Air supply lines
- Air change-over valve does not work. - Secondary air injection pump
- Vacuum system leaks
Thank you for the reply! I checked to see if the pump is working and I can feel it vibrate after a cold start, which leads me to believe that it is functioning. What is the best way to test the pump?
