Hi all.
My 2000 C2 Cab has passenger rear window problem; it does not move up or down as I push on its switch. It last operational was when I close the top in the 105 degree heat in Palm Springs. The window came up (but not all the way) and the top was closed fine. I checked the window and it seems like the window is disengaged or broke off from the regulator cable or belt, because I can grab the window and pull it up or push it down.
I need help here. Does anyone know here I can find the instruction of rear window removal or has done this job before which will share the information. I searched Renntech for the DIY or threads about this topic but had no luck.
How difficult is this job or I should bring it to the dealer or independence shop? I like to do the repair job myself to save some bucks.
Thank you in advance for your help.
Nghia Ho
