Hi everybody,
I have a problem with my Cayenne 2008 backdoor locking system.Though the door engine is functional, the door can be opened only from interior.
Is outthere somebody that knows how to remove the backdoor interior cover/ Or better has had solved by himself such a problem?
Tks a lot.
I had a problem with the rear hatch switch on my Cayenne S and it had to be replaced. As a temporary way to open it: Inside the cargo area at the rear hatch door, remove small square plastic cover at the bottom center of the tailgate, stick finger in mid center bottom feel lever and lift up.
