Hi, I have a 97 Boxter with a used engine that has about 25k miles. This morning my car wouldn't go in reverse. The gear shifter is loose but goes into the other gears. When I put it in reverse and give it gas, the car pulls forward. Any idea's or thoughts on this would be greatly appreciated.
Thx, Cyn
Check gear selector mechanism on the gearbox if bent it will cause this maybe something jumped up and hit it if bent bend it back and everything should be good
Thx, Cyn
Check the connection of the shifter cables to the transmission.
Here is a link to a similar problem I had PRESS HERE
