I notice when accessing the engine there is a lot of foam and rubber pieces that just kind of sit in place over the engine cover. Is that sound proofing or is it needed for temperature insulation? I ask because if its soundproofing I'm probably going to remove it. Has anyone de-soundproofed their Boxster before?
I believe the correct answer is BOTH.....without that thick layer of padding and even with the top of the engine bay closed it's LOUD and it get's HOT. I have driven the car in both configurations with and without and with and without the engine cover on. BOTH were not very pleasant. it was only for a short time to do some 'listenting' I was glad when then the whole thing was put back together. Unless it's for weight reduction for racing I'd leave it.
I'm doing it for sound. The main thing that sold me on wanting a Boxster for years was its looks and the sound. I hate driving with the top up solely because of the sound proofed engine noise is alot weaker til you get to 4 or 5000 rpm. For this reason I have the top down 99% of the time. Even in 100+ weather like its been here the past month. So would it be a bad idea temp wise to remove it?
Edited by blues3531
I was thinking about doing the same thing. I'm hesitant though because I don't know what the heat would do to the rear window. Let us know how it goes
I never thought about that. I'll probably be trying this out next week sometime on my vacation.
