B) I have a 99 carrera 4 I use the manuel shift with the tiptronic all the time. A few times I was down shifting from a high speed and hit first gear at 40 or so when I went to take off in 1st gear I got a little bit of slip and it tried to shift into 2nd gear. I let off till it hit back in gear and all was fine I was able to up shift and down shift with no slip most all the time. I was getting a open sensor code 7040 then I cleared it and it did not come back telling me I have a open sensor? Any Idea on what to check so I do not damage this trans>>?
Dan
