  On 7/26/2011 at 8:44 PM, BlackC2 said:
Where do I buy a new motor? Water in cylinder 5 and water in oil. 90,000 miles and a new Tiptronic.
You might want to consider rebuilding instead. A lot more people are doing this with the M96 engines and upgrading parts during the process (IMS bearing.)
Member Dharn55 rebuilt his motor after a cracked head. Member Logray just rebuilt his as well. Neither fellow had any previous experience rebuilding an engine. Do a search here and you will find a lot of info. I feel your pain. I lost a motor to intermix on a 2000 996 years back. There are more options now than then.
You other choice would be a "reman" engine from Porsche (about 25k installed.) or buy one from a wreck (aka Porsche Dismantlers.) Cost varies here. 3.6's are pretty easy to source.
I believe you could rebuild it your self for about $5k to $7k. Or you could buy one from people who rebuild them. Not sure of cost there.
I hope this helps and I'm sure others will chime in and give you some options..
Try Vertex in Miami. They also do overhauls. I believe they charge approx 9-10K for a 996 overhaul. 1-866-668-0660. Ask for Gilbert. They ship worldwide.
I just bought a rebuilt Tiptronic from them! They don't have a 3.6 in stock.
Does anyone know Instant- G? http://www.instant-g.com/index.html
  On 7/31/2011 at 3:15 PM, logray said:
If you want something from who is considered the upmost authority in the world for the M96/7 engine, buy an engine (or get yours fixed) by flat 6 innovations.
They can rebuild, but if yours is "too far gone" they also sell complete used and/or "new" engines including many upgraded parts.
http://www.flat6inno...m/shop/home.php
They are booked until April 2012
I just had a remanuf Porsche engine dropped in by PowerTech in Northern NJ. I guess you're looking for minimal investment? I went balls-out and took the full hit.
