Hey Guys,
A friend of mine has the error 8059 from his car, Instrument Cluster says Airbag fault, the description on the Durametric is Driver's-side Sensor. I couldn't figure out which sensor this is. Is it the seat sensor?
Hmmm... airbag codes are usually 69xxx - HVAC codes are 80xx.
But 8059 does not come up on my list. Any chance you can get the car to a PIWIS tester?
Just tried it on a PIWIS, it came out as 8059 Driver's Airbag Sensor also.
Any ideas?
  On 7/27/2011 at 2:03 PM, Loren said:
There are two sensors in the steering column.
What are the two sensors in the steering column?
  On 11/4/2012 at 2:43 PM, bencomer said:
I have an 8059 fault code on my 2006 997S, and the airbag light is on. What does this mean?
I have removed your duplicate post on the same subject. Please re-read the board Guidelines/Rules if you are unclear.
Have you (or a shop) had the steering wheel off recently?
