my 1998 boxster idles fine but when you try to press accelerator acts like starving for fuel. I changed the fuel filter, fuel pump checks ok and I cleaned the mass air flow sensor. I don't know what to check next and need help. thanks
Edited by scoop986
I checked the codes yesterday but have lost them and computer has not reset. One of the codes was 1123 and the other 2 were same area but differant banks. (oxy sensor)
Since i posted i disconnected the mass air flow and it cranked and ran much better above idle. I am thinking it is the mass air flow sensor.
Edited by scoop986
