Hello everyone! Quick question...If I tie-wrap the pad sensor cable and do not connect it to the pads, will the warning light go on in the dash? I read in another section of our forum that you can snip and connect the cables closing the circuit so that the light will not go on disabling the sensor. The car is a 1999 Carrera. Thanks again!!
George
George
If your light is currently not on just tie them back. Otherwise determine which wheel has an open circuit and snip and connect the cables. I would recommend soldering them and and then use heat shrink to protect them from weather.
George
The light is not on so I will just tie the sensor and save the drilling on the Hawks HPS pads. Thanks for the info.
