I think you should have two. I believe the second battery became an option in 2006 when battery conservation electronics arrived. Other more knowlegable folk will chime in I am sure. It is easy to check though. Take out your spare wheel and take a look
PKN
I have the expensive full size spare wheel on the back of my cayenne boot. And in it's place has a box with Bose on must be an amp or sub
Have a look at your options listed on your VIN/options decal.
IJ2C is the code for the dual battery setup.
Aux baterry is located in the back where the spare tire area is. You can't miss it if there is one!
2003s had 2 batteries sometimes, not many 04's had 2 unless ordered. My bet is that you have only 1
