I've just had my 997.2 Carrera S serviced and the local OPC recommended that I pay them to clear the radiator vents and bulkhead drains as well as replace the wiper blades.
As they had already annoyed me (another story...) I turned down their offer to relieve me of another ~£200 to do what sounded like simple (and potentially unnecessary) jobs.
So... are they simple jobs (apart from the wipers - I know that's simple!)? If so, could someone point me in the right direction as how to do them please?
:thankyou:
If you have a vacuum with a small inlet tube you can get most of the debris without taking the bumper off. Use a flashlight or other light source to examine the radiators.
If that does not work to get most out then you will need to take the bumper cover off and do a through cleaning of both radiators and AC condensers.
There are small drains near the battery. They go to
the underside of the car. A small wire is all you need to make
sure they are open. Clean the leaves out around them.
Paul
