The shop obd2 reader was originally only picking up the P0430 cat code. I cleaned my maf, poured some techron cleaner in, and reset me ecu. 50 miles later and armed with a Durametric, the fault code returned along with P1128 and P1130- Oxygen sensing adaptation idle range bank 1 and 2.
Any ideas on what's going on? My oil cap is on tight, and there are no driveability issues. I hope I didn't screw up the maf, but I would think just spraying it with maf cleaner wouldn't break it...
Please do a search here as this has been covered dozens of times.
You have an air leak - perhaps a bellows and/or AOS leak. Do the inspections/tests to confirm.
Clear you trouble codes with the Durametric, you may have created the P1128 and P1130 when you opened the oil fill cap testing for AOS issues.
Jager
