Does anyone know the differences between these M030 Front Sway bar part numbers, in terms of diameter and thickness size, along with stiffness:
996-343-701-21
996-343-701-23
http://www.cb-racing.com/boxster_030.html
I was using the above website and could not find these part numbers with corresponding diameter, thickness and stiffness.
I checked Pelican and didn't come up with any tech info.
996-343-701-21-OEM
Original Front Sway Bar, Boxster S (2000-04), Boxster with M030 (1997-04), Each
Brand: Genuine Porsche [More Info]
$367.75
996-343-701-23-OEM
Original Front Sway Bar, Boxster S (2000-02) with M030 (USA and ROW), Each
996-343-701-21
996-343-701-23
http://www.cb-racing...oxster_030.html
Edited by DFW911TT01
996-343-701-21-OEM
$367.75
996-343-701-23-OEM
I actually checked out Pelican already.
996-343-701-21
996-343-701-23
21= Base M030 23.6mm 3.5mm
23= Box S M030 24.0mm 3.8mm
Suggestion from an old track rat: If I wanted to do a custom sway setup using Porsche bars, I would put the Base M030 on the rear and leave the front alone. YMMV
Thanks Topless.
I currently have the Base M030 rear sway bar and stock base front sway bar now. I like having my Boxster more neutral to oversteer for Autocrossing. I'm planning to sell the M030 front swaybars and that's why I needed the information.
