I have a 2004 996 Cabriolet with 30K miles on it here in Miami Beach (unfortunately it is black/black which looks great but gets **** hot in the summer sun) I noticed when driving in sandals/shorts (actually bare feet) with the AC on that I feel some cold water droplets hitting my right ankle. I feel the droplets about once every 3/4 minutes only with the AC running. With shoes/socks you would never feel the amount of water.
IS there a drain that is either potentially clogged or disengaged that would be causing this?
Thanks in advance - Steve
I'd bet more on the drain being blocked by either debris or mold, common on these cars in very hot, humid climates. Wurth and others make some stuff that you can spray into the system that will both clean it and kill any odors at the same time. You can see the drain line from below the car and can blow some air through it to clear it before spraying in the cleaner.
