Hi all,
First post on here!
I returned from holiday to find a flat battery, after following the jump start instructions the car started ok.
I was met by the message system error: phone, navigation system, amplifier, cd changer not available. Has anyone else experienced this before or anything similar?
Perhaps a coincidence, I also had water ingress to the cabin on the drivers side caused by blocked drain at the roof (right hand drive car). I noticed this at same time, could it be related?
Any thoughts would be appreciated as the car is out of warranty.
Many thanks
Stephen
Ps I have checked the fuses that I think are relevant but again if any of you guys more experienced with this can clarify exactly what to look for it would be appreciated. Thanks
  • 2 months later...
