Hello,
I'm in the final assembly stages of my engine and can't seem to locate the torque setting anywhere.
I found the intake riser specs, but not the manifold to the intake riser.
1999 996 C2
Thanks in advance!
What is annoying is the section in the fuel manual that covers the intake distributor lists the bolt just like it does in other parts of the manual. But under install notes there is not a torque value listed, just blank.
Perhaps I should just treat it like any other generic M6 fastener, and torque to 7.5 ft lbs. I don't want to damage the green o-rings.
Just to clarify, here is a picture of the bolt I'm trying to find specs for. Thanks again.
Correct torque is 9.7 Nm, or 7 Ft Lb.
Edited by JFP in PA
Thanks JFP.
I found this spec in the WSM:
However i interpreted that as being the intake riser to head.
Perhaps that spec is for both the riser to the head and the plenum to the riser?
Thanks JFP.
They are both the same torque specs.
