Brakes not fully working properly. pedal firm. feels like only about 50% effective. emergency brake ok.car will stop. flushed and bleed system with type 4. no help no fault codes. psm on or off, no change... 2006 C2 carrera. stock. 20k miles.
any suggestions. thanks, tom
FIXED. found crack in the back of a plastic vacuum line behind engine air cleaner. crack was at the joint of the metal tube with the plastic. no vacuum supplied to the booster, thus, manual brakes, no assist. hope this helps anyone with same issues. tom
