does anyone know how to remove a dent in the rear bumper of a 2004,4s???
The bumper covers are a plastic composite. Depending on the severity and if the paint is damaged, you can likely get a small dent out with some mild heat and hand work it out. Be careful not to over heat
as you may damage the paint and/or bumper cover. If the paint is damaged, or if you have torn the cover, you will likely want to get it repaired professionally. Tears can be repaired with plastic welding or various
epoxy mixes and completely resolved by professionals.
Good luck.
DC
