I recently picked up an '03 986S with standard seats, and the driver side seat height adjuster seems to be broken. I can make the adjustment on the passenger side without any issues. The driver side lever moves freely and does not appear to be connected to anything.
Any thoughts about what the issue might be? I would really like to get this resolved as it's stuck at full up and that is way too high for my comfort!
:thankyou:
:thankyou:
Start by checking under the seat to make sure nothing is obstructing the movement - believe it or not that is a common problem.
If there are no obstructions check fuses E3 and E4 (both are 30A).
If the fuses are good then you may have a bad motor.
These are standard seats, so the height adjuster is manual. I peaked underneath using a mirror, and can see that the lever is connected to the cable that actuates the hydraulic strut (it looks the same on both sides), so the problem is further along. See part #20 here. I've got the torx sockets now, just need to find some time to pull the seat out and see what it looks like underneath!
On my 02S, seat height adjustment requieres that I push the seat towards the back (by pushing with my feet).
Turning the lever itself is enough.
My seat goes down, but it won't stay there, the lever is connected to the strut or shock under the seat, I can push the seat all the way down. I moved back and forth the seat, but still at the highest setting, any one with info on this
Okay, finally pulled out the seat today. Everything was attached as it should be and there was nothing obviously wrong- until I pulled out the gas strut. That thing will not budge! Guess that would explain why the seat is stuck at the full-up position. cool.gif Next up is to find a replacement strut and get it back together. Can't wait to sit at a more comfortable level!
Picked up a used strut today from a local dismantler, and after installation I now have an adjustable drivers seat! Especially nice to do it for 1/3 the price of a new seat strut B)
