I need to remove about 1/2 liter of oil engine after overfilling.
After some reading, it seems that the recommended way is to remove the filter cover.
I assume I could only jack the car up on the left side, remove the wheel then remove the filter.
Is my understanding correct? (I'm concerned that the all 9 quarts will flush on the floor...)
So I would greatly prefer to remove oil from the filler in the trunk using vacuum.
Anybody ever done it?
What is the diameter & length of the pipe to use?
Thanks guys
Chris
Thanks guys
Chris
Removing the filter housing will not cause you to lose all the oil, and the housing only holds about 1/2 quart or so. Be sure to install a new o-ring. And you will never get the oil out using a vacuum system from the filler.
Edited by JFP in PA
